LS/VTEC Turbo??????
Old Jan 29, 2004 | 07:40 PM
99B16Si's Avatar
damn were droppin live flies. im the blue si across from their shop with no motor in it
Old Jan 30, 2004 | 01:52 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
Originally posted by tegasaurus
The one limiting factor in an LS engine, in any application, will be the poor flowing characteristics of the head. Better flow is one determing factor in making more power.
A) The flow of the head is irrelivant when talking about LS/Vtec because you dont use the LS head, thus the "LS/Vtec" name...
B)As far as I know the flow of the LS head is not bad, and I know it hasnt been a "limiting factor" to me....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jan 30, 2004 | 07:43 AM
racin's Avatar
ZMR
Default yo
Originally posted by cochese
tk....................herd he was racing a civic...something gave??dont know what yet.
also i herd sone blew his shit up on his way to oklahoma??
he must be pissed,man i hope he rebuilds!
i talked to kevin,i guess i'm gonna be at the shop sat-or sun morning to get this ___*b*rdata__ tuned?????????
My wastegate blew off my manifold....the piece that connects the manifold to the wasegate just cracked..came right off.....The motor is fine I'm driving around all motor now until me+kj get enough time to make one.....
....For the ls/vtec question theres nothing wrong with it build it right and it'll last 4 ever
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
Old Jan 30, 2004 | 08:34 AM
tegasaurus's Avatar
vtec where?
People lower compression, to increase the margin of error. To be able to run more boost, without the added risk, of the added heat from the compressed air, on top of higher level of heat within the combustion chamber because of the higher static compression. Low compression with massive amount of boost will yield a sluggish low end, but will support huge amounts of power on pump gas and alot more torque from running alot of boost. The most critical aspect, in deciding wether to run higher or lower compression, is the octane rating of the fuel being used.
Low compression you can run massive amounts of boost on pump gas, have less thermal stress on the engine, but at the expense of maxxing out most compressors on the pump gas level. A high compression engine runs less boost on pump gas, but has the ability to make a greater amount of power on race gas.
99 gsr
- B18b -
349 whp - 299 ft/lb
