Bouncing Idle
Old Jan 28, 2004 | 07:41 AM
Fermunky's Avatar
King Ding-A-Ling
Default Bouncing Idle
I have a 94 Civic Dx. I just put another 1.5 sohc motor in it. It was throwing code 10 and 14, but now isn't (found a plug not plugged in ). The only problem I have now is the idle is bouncing. What is the cause and solution for that?
Old Jan 28, 2004 | 07:52 AM
GOTTI's Avatar
OEM Parts Specialist
check the valve underneath the intake manifold...theres 3 or 4 10mm bolts and a hose or 2...take it off and screw the valve inside back in because over time it unscrews itself. then put it back together and you should be good...i have had to do that a couple of times...
Old Jan 28, 2004 | 08:18 AM
spoonfed's Avatar
Tha numba one stunna
search in this forum there have been 59,540,045 posts on this problem in the last four hours
... content in sig not work friendly
Old Jan 28, 2004 | 11:13 AM
crix's Avatar
:mugen member:
code 14 idle air control (if U unplug it it will may stop idling like it is
but will still throw same code)replace it or fix it......
code 10 intake air temp sensor,check w/ a volt meter,CHECK to see if you have crossed the 2 plugs for the sensors,I think these 2 sensors have the same plug..they could be in the wrong place ?
Old Jan 28, 2004 | 11:17 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
