timing belt broke what to do
Old Jan 27, 2004 | 11:45 PM
Walter's Avatar
Im as loyal as my options
Originally posted by crix
do a compresstion test to see if you bent any valves,I dont think
you did because the d16y8 head has less compresstion & is taller than the d16z6 head.. I snapped a few of sohc T-belts & no harm was done to the head..or valves..put a T-belt on & go from there........
the extra head he has now is the d16y8, the car still has the original d15 motor in it. also, his water pump was about to take a shit, would that of had anything to do with it?
blah blah blah
Old Jan 27, 2004 | 11:46 PM
Walter's Avatar
Originally posted by Gringo003
well i think i am just going to do the mini me swap anyways just to do it its needs to be done i got everytign just need to get the ballls to do it im sure i can do it but ive never done it before
i think you will be ok
blah blah blah
Old Jan 28, 2004 | 05:55 AM
Gringo003's Avatar
B.B.C
Old Jan 28, 2004 | 06:01 AM
01Ls-RTeg's Avatar
Genius v3.015
don't waste your time listening to these people. just get a new engine. chances are a valve probably dropped and your engine is fucked and would cost just as much to fix it(ie. hone and bore walls, replace pistons, new head all new valves springd and retainers) just get a new engine.
Yes, I do talk to myself, it is the only way I can have intelligent conversations.
Old Jan 28, 2004 | 08:27 AM
40ozCasualty's Avatar
shift_lock
Yeah when the water pump kicks the bucket they like to lock up, Heres a picture of an Si block&Timing belt from a CRX thats water pump went bad.
Old Jan 28, 2004 | 08:41 AM
  #17 (permalink)
insanecivic94ex's Avatar
Just_Pimp it
I just did a mini me swap. Right now i hava oil leaking out of the dizzy dont know why. Here is a pretty good link on how to do one and the stuff you need. http://crx.honda-perf.org/articles/z6swap/z6swap.html
"He who makes a beast of himself gets rid of the pain of being a man."
Old Jan 28, 2004 | 11:26 AM
  #18 (permalink)
crix's Avatar
:mugen member:
Originally posted by Cronic
The Y8 head has a smaller combustion chamber, and has MORE compression. (relative to a z6)
the combustion in the y8 is like a b16 head
but whatever, I had a Z6 motor that ran strong,then I put a y8 head on & it lost power,dyno proven......... doesnt matter really,
this guy just needs to fix is timing belt.....
Old Jan 28, 2004 | 12:48 PM
  #19 (permalink)
Gringo003's Avatar
B.B.C
so a y8 head on a z6 block sucks then ?? that was my next thing i was going to do put it on a z6 block
