Horrible Smoke
Old Jan 28, 2004 | 12:30 AM
styles999's Avatar
Powered ByYo Mommas Mouth
sounds like piston rings, especially since when oil burns it puts off a blue color. and you noticing a horrible buildup of carbon on the pistons should have given you a clue, unless they were like that when you got it, then it could be just burning off whats on them.
Old Jan 29, 2004 | 12:43 PM
Janky99's Avatar
Honda Guru
Hey i did another compression test today, remember, this is a mini me so the c/r is really high, came around like this: Piston 1=180 2=225 3=240 4=240
Old Jan 29, 2004 | 02:39 PM
Janky99's Avatar
Honda Guru
I put some stop smoke in there, it doesnt smoke anymore until 3000 rpms, it starts bailing out white smoke... anyone have any ideas at what could be causing this...? please i need some help, thanks tho. -Ben
Old Jan 30, 2004 | 03:22 AM
  #18 (permalink)
Janky99's Avatar
Honda Guru
thanks for everyones help, ill be changing the rings tomorrow so ill keep you posted to see if thats what is. thanks again -Ben
Old Jan 30, 2004 | 02:13 PM
  #20 (permalink)
Janky99's Avatar
Honda Guru
theres like one other thing that it could be, headgasket. since thats going to get changed also, so im knocking out basically the 2 possibilities, also, when i get back into it, ill find out if the cylinder wall is scared, if so, i have 3 spare good blocks laying around. I like to do things to learn and it gives me more experience in the rebuilding. thanks for everyones help. -Ben
