leanin out badly
There are alot of different theories concering sizing injectors for a particular setup. Most people think bigger is always better. Honda's from the factory are tuned with injectors reaching 100% duty cycle at redline. . . that has to count for somehting.
Although, larger injectors do lessen driveability slightly, it is definately better to be safe, rather than sorry. I'm running 720cc injectors and I'm at about 99% duty cycle at ~25psi at 8k rpm. So I personally would rather be safe.
99 gsr
- B18b -
349 whp - 299 ft/lb
99 gsr
- B18b -
349 whp - 299 ft/lb
inform me on how larger injectors will lessen your driveability? (to a certain extent) im not referring to 1000cc+ injectors. just comparing 440's to lets say 720's. ive never once seen this be an issue as long as the tuner knows what theyre doing
First of all, the larger the injector, the slower rate it opens and closes, due to the higher volume of exiting fuel. Thus making a larger injector noisier, and if the injector is opening at a slower rate this will definately have a direct effect on how fast the injector can respond to immediate changes in throttle position. Obviously, you have somewhat of an understanding of this, by the fact that you typed (to a certain extent). A change in the size of injector, period, will in turn affect that particular engine's ability to respond quickly, to change.
As well, I never said it was an issue, just definately something noticeable, regaurdless of how knowledgeable your tuner is.
And for the issue of an injector coming from the factory at 100% duty cycle. I am definately not confused, an Integra gsr, factory settings, at 0.8" of MAP pressure at 8525 rpm, the factory injectors are at 100% duty cycle. The higher the cycle you run a specific injector, the better the spray pattern gets, considering you are reaching it's maximum recomended cycle.
99 gsr
- B18b -
349 whp - 299 ft/lb
99 gsr
- B18b -
349 whp - 299 ft/lb
ok wow, information out the goats but, but i'm goin to go with the hondata s200 with boost option. now i can get that from secret services, but do i order it from there and then when i go there they will install it and then tune it or what is the deal with that i'm not full understanding. thanks
ok when i get all of the fuel issue stuff handled and straightened out, i've got eagle h beams and je pistons balanced everything, how many lbs am i lookin at max on this bottom end?, and will i be able to squeeze 400 hp out of it???
