brake light??? please help
Old Jan 20, 2004 | 02:25 PM
KJ's Avatar
KJ
bored at work
there is a limit switch on the ebrake. Yours might be busted.
Old Jan 21, 2004 | 12:09 AM
crix's Avatar
:mugen member:
agree w/kj or it maybe the brake switch going bad on the the brake pedal if U need help pm me asap
or ca#
Old Jan 21, 2004 | 02:43 AM
Janky99's Avatar
Honda Guru
if your brake light always stays on, try adding brake fluid, could be low, it shares the same brake light as the e brake does
Old Jan 21, 2004 | 03:12 AM
crix's Avatar
:mugen member:
IM talking about the brake tail lights If they do not work then it could be the brake switch....?
Old Jan 21, 2004 | 07:11 AM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
if the BRAKE warning indicator is on and you added fluid check the cap it has a sensor in it that goes bad its the level sensor its foam sometimes they just go bad ive replaced mine on the lude 3 times. The foam shit inside sux as a protectant and it just goes bad. If its tail lights check your E-brake like KJ and CRIX said or your break swicth is faulting.
