Will I have to much lag?
well the uberdata will be tuned by vertigo on the board who wrote his own version of it and uses it in his boosted teg and i planed to get it dyno tuned at secret services
... content in sig not work friendly
Well, the most important thing is to use whatever your tuner is comfortable with, and if you're happy with the results, then that is all that matters.
99 gsr
- B18b -
349 whp - 299 ft/lb
99 gsr
- B18b -
349 whp - 299 ft/lb
Werd.
What is "CROME"???
NonVtecEG93 I would definately recommend getting something providing a little more control, like something along the lines of hondata, or maybe even crome.
spoonfed for you as well, I would definately recommend getting hondata, which is what I am running and have had a pretty good experience with so far. I would also recommend against using uberdata, comparing it to something similar it is not even close to the quality of crome.
John cui is an asshole, uberdata is functionally more complete than crome. Crome has a more user friendly interface which makes ignorant people (like yourself) think it is better. You have much to learn
While crome is constantly being updated
Uberdata has been updated 4 times this year alone to add features and fix bugs.
there were still a number of bugs being worked out
Of course there were bugs, Uberdata had bugs, and Crome is and always will be based on Uberdata code.
I ran crome and had excellent results (mainly considering it was free).
This thread is way off topic...
The more I read your post(s) pertaining to Uberdata and Crome, the more I realize that your conclusion that Uberdata sucks is based on nothing... if it's just your prefrence, then say so. No need to bash Uberdata. If anything you should be thanking Vertigo for writing the base to your favorite program.
AIM: IntegrVTEC <-best way to contact me.
I would not get a 63 a/r. Go with a 50 trim but also think about precision turbos
drew
drew
NEED PARTS WTB: Turbo Timer, TIAL 38MM+ WGATE, Race Manifold, etc
NEED a FPR installed!!
White 97' kouki RIP
Green 96 TURBO
White 97' kouki RIP
Green 96 TURBO
Not really trying to talk down about any particular choice you may make, just my personal experience with uberdata is it sucks.
Once again, if you read my first post, I was not trying to talk down about uberdata as a choice, just sharing my experience using it was not a pleasant one.
99 gsr
- B18b -
349 whp - 299 ft/lb
99 gsr
- B18b -
349 whp - 299 ft/lb
I'm just curious, which version of uberdata di you try? You talked about it like you tried last year or something. You cant compare the first version of uberdata to the latest version of crome. Personally, I dont think crome's interface is that much better than the current uberdata's interface. And if you meant it as your personal humble opinion, you should have chosen better words and not tried to beat your ideas into peoples head thru your many negative posts about it in the same thread.
This is getting fun!
Spoonfed, I have 243.1 jackass.....And you run more HP than me
also have it under my foot when ever I need it
Kris
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
Yeh, it was a little while ago, I don't think I have seen the new versions of uberdata.
Anyway, whatever works for you, is great. The final result is all the matters in the end anyway.
You are right, I could have rephrased my words better, to get my opinion across in a less harsh way. All I was trying to do is share my experience's, to possibly help someone make a more informed decision, and by talking down about your program without good explanation, didn't really help.
Anyway, I would definately like to try out the new version if you wouldn't mind sharing. . . Can it currently support a 3bar?
99 gsr
- B18b -
349 whp - 299 ft/lb
99 gsr
- B18b -
349 whp - 299 ft/lb
