ls in del sol
Hi my sister has a 93 del sol S. I was wondering if an integra ls motor would swap right in as it does in some other hondas... IF so what all would be needed in the swap?? and what would the estimated performance be?? thanks
Guest
Posts: n/a
yes it swaps in... you would need a full 94-01 LS swap... the only thing that i can think of that is not direct bolt in, is if you get a 96-01 there will be some wiring and ECU issues... nothing major at all... but all the physical parts swap in...
-Keith
-Keith
Originally posted by `92CXhatch
like i said full swap from the LS...
-Keith
-Keith
You would need to call a shop to get a quote for this, i would suggest ZMR, PM KJ for that one, or Secret Services, banners are all over the place. As far as how fast it would be, you should expect around high 15s close to stock with a good driver.
