headlight problem???
Originally posted by vtecready
My car did the same thing I hit the headlight a couple of times and it turned on and has stayed on for about 2 months you could also try some wire cleaner that might help.
I do not think hitting will make any difference. Check to make sure all electrical connections to that bulb are secured,the wire coating is intact. It is isolated to the one bulb so I am going to assume that is a bad electrical connection.
