brake lights problem
Old Jan 6, 2004 | 08:30 AM
Juiced_Sol's Avatar
LS1FTW
Default brake lights problem
The problem is when my headlights are on. The brake lights do not dim when the brake pedal isnt being pressed, they stay fully on the whole time the headlights are on. But when the headlights are off they work fine (they stay off until brake is pressed). So i know it not the switch behind the pedal being stuck.
Does anyone know what the problem would be, and could also fix it, if its not something simple.
thanks...
Old Jan 6, 2004 | 08:36 AM
Punkinterviews's Avatar
Chavez Motorsports
it's usually a little rubber ring that wears out and needs to be replaced under the dash on the brake pedal....You might find pieces of it on the floor board. LMK What kind of car you have.
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Jan 6, 2004 | 10:09 AM
Juiced_Sol's Avatar
LS1FTW
1993 del sol, i didnt see a rubber ring yesterday when i checked or pieces of one.
Old Jan 6, 2004 | 12:10 PM
crix's Avatar
:mugen member:
unplug the brake switch and turn the headlights on & see if it still
comes on,if it doesnt then the brake switch maybe going bad.
Old Jan 6, 2004 | 03:09 PM
Juiced_Sol's Avatar
LS1FTW
ok..I unpluged the switch with the headlights on and the brake lights stayed on. With the headlights off the brake lights didnt work at all.
Old Jan 6, 2004 | 09:25 PM
User1578's Avatar
My blowoff valve goes Moo
Sounds like you may have a short. Have you ever put a fuse bigger than recommended size in the fuse box? You could've melted wires together if you did. My car ran fine for over a year after I got it, then all of a sudden a bunch of wires fused together. After lookin around trying to figure it out, I found a 30A fuse in a 10A slot...
AIM: IntegrVTEC <-best way to contact me.
Old Jan 7, 2004 | 06:29 AM
Juiced_Sol's Avatar
LS1FTW
nope never replaced any fuses since i got the car, and never did this until recently.
Old Jan 7, 2004 | 06:41 AM
MattC's Avatar
Professional Asshole
sounds like u have a short... that's always a fun time pulling out wiring...
Semper Fi
Aim and Yahoo- Inkedupordie
Old Jan 8, 2004 | 06:06 PM
Juiced_Sol's Avatar
LS1FTW
anyone... theirs no melted wires/pulled wires
