how much boost???? 2000 civic SI
Hey guys, im a local female racer and im new to forced induction. I have a 2000 civic si turbo, with the following mods, how many pounds will the stock internals handle??? i have it on the stock wastegate settings of 7.8 psi now without it being tuned. It drives nice now but i expected more for $6000 dollars i spent, when i went to Gainesville Speedway it ran a......
R/T........582
60'.........3.107
330........7.347
1/8........10.509
mph.......77.96
1000.......13.193
1/4.........15.412
MPH........101.83
I know my 60ft are SORRY! i have a big trouble with traction,so please don't critisize me on it, but it was untuned and my last run before i found out my motor mounts were all damaged! N/A i ran a 15.5@86????? on the street it pulls so much harder now than N/A. i want to turn up the boost or something but i dont know, maybe you guys can help me out with some helpful advice. with my list of mods what can kinda boost and 1/4 mile times should i expect?
Greddy TDO5H 18G Turbo @ 7.8 PSI(Greddy Kit)
Ported 8cm2 Exhaust Housing
310cc Injectors
Airinx Air Intake
Greddy Type-S BOV
Greddy "BIG" Polished Front Mount Intercooler
Polished Intercooler Piping
Walbro 255LPH Fuel Pump
Jackson Racing AFPR(60PSI-Idle,70PSI Boost)
AEM High Flow Fuel Rail
AEM Fuel Pressure Regulator
Skunk2 Adjustable Cam Gears
NGK R Spark Plugs
Stock Plug Wires
MSD Blaster SS Coil
MSD Modified Distributor Cap
MSD 6AL
Missing Link
Jun Lightened Flywheel
Act 2900 Clutch
Apex-I 2.5 inch SP Cat Back Exhaust
2.5 Inch Custom Down Pipe
Test Pipe
V-AFC Apexi Fuel Computer
Greddy Profec B Boost Controller(Not Even On, Using stock wasgate settings)
Greddy Turbo Timer
ok so when i take it to get tuned in orlando, how many PSI should i tune it too? leave it at the stock 7.8 psi from the wastegate? or can with all the other supprt mods that i have can i tune it to lets say around 10psi??? and what numbers should i be expecting from my set up???
thanxs,
Jessica
R/T........582
60'.........3.107
330........7.347
1/8........10.509
mph.......77.96
1000.......13.193
1/4.........15.412
MPH........101.83
310cc Injectors
Airinx Air Intake
Greddy Type-S BOV
NGK R Spark Plugs
Stock Plug Wires
MSD Blaster SS Coil
MSD 6AL
Missing Link
Act 2900 Clutch
Test Pipe
Greddy Turbo Timer
thanxs,
Jessica
hey jessica you can boost around 10 psi safely ,but you might want to look into bigger injecters etc i have a 92 hatch with a h22 and a t72 turbo and i boost way more than 7.8,but that is because you have a smaller turbo at all depends on how and who tunes the car, the best thing i can say is do a little reseach there guys on here that know there shit just ask vito os crix these are thier screen names
want a smoke and a pancake
Jessica,
To answer your primary question, a b16 can handle 7-11 psi of boost w/ no problems if tuned properly with factory internals.
More boost is NOT your answer!
If you are looking to have better ets:
Fix your traction/motor mount issues 1st.
I highly recommend atleast a hasport top drivers side motormount for an ek w/ a bseries motor in it (si).
I also recommend falken azenis tires for drag radials because of the price & availibility...
a. Have your car tuned
b. Make sure your drivetrain tires/axles/tranny/clutch combo can handle the power you are putting down.
c. Practice launching on an empty road...
Make sure you know where to launch at without:
1. loosing traction to where you can't regain it without letting off the gas
2. launching so low you do not leave the line with any power hence your car falls on its face
After a few launches you will find an rpm range you can launch at.
What did your car dyno (max power), or have you even had it tuned yet ?
With 200-250 whp in a civic si you should be in the 13's.
If you need more horse power, look into getting your self some cams
If your still lost after reading this, you might want to consult a local professional like John at secret services.
with a 101 mph trap speed u definetly have the power to be in the 13s no problem. work on the launch and you'll be fine. a great car is only as good as its driver!
With that turbo you can safely boost probably 10psi...although there is no way to really tell unless you have it tuned to a safe amount. mtber knows what he is talking about and i would do with his advice. Some sort of standalone system would be nice or atleas an AFC to make tuning a bit easier! Good luck
B18C1 build: Looking for 400+on pump gas. slowly coming along
dont feel bad, when my 300ZX was having issues with the crank angle sensor (basically it had to be street started or else he magnets would shake and read RPM ERROR to the Standalone and shut the car off) I ran a 15.4@124.4 LOL I know all about stupid technical things fuxoring your 60 foots... Then again i was street starting the car... no boost in 1st.. 5 psi in 2nd... and finally 15psi in 3rd thru the traps where I made al the MPH
I dont feel like a sig today.
wow u guys are right boost is addicting i cant wait until i get me some
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
