Brake problem...
Tattoo the Planet
on
Brake problem...
I just did the brakes of my civic dx and I'm getting some interesting results I've not run into before. Initially they go almost to the floor but do stop the car. I pump them up and they do not fade at all. I'm figuring no air in the lines but I'm not sure. Any help is appreciated. By the way I replaced the back brakes.
JPsacred
JPsacred
engine building &best
on
sounds like you did not bleed them or you have a crack in a line or if you did bleed did you tighten the boltback
i love AUTOZONE
i love AUTOZONE
If you open the line then you need to bleed the brakes, but if you just changed the pads, when you push the piston in then you only need to pump up the brakes up and the it will be fine.
like crix said you need to bench bleed the master
"STRICKLY MT" Shop open for business
Tuning available for S300 and Kpro
727-510-6301 Tristan
11.99@116 All Motor K24 Civic Eg6 on Drag Radials
MattBuilt
MattBuilt
