please help on turbo questions
ok i have a couple questions on putting a turbo on a 89 hatch with an ls
how much boost is safe to run on stock internals?
should i get a fuel pressure regulater or a fmu or does it matter?
can i fit a garett t3 with a tubular manifold or is the room to small?
thanks please answer any questions if you know thanks
i concurr, just keep it somple, if you have attainable goals you should be fine.
be forewarned boost is like crack, 1 time and you are hooked
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Originally posted by philly blunt
thanks man
how much do you think ill get to the wheels with this and skunk2 intake manifold and straight pipe w/ muffler? runnin lets say 4psi and 6psi
thanks man
Originally posted by integra_nemesis
depends....i could give you an estimate, but it may be wayyyyyy off. 8-10psi and you could expect about 220-230whp. don't waste your money on a T3/T04E if you're only gonna spool 4-6psi. my suggestion is that you get that turbo though and run at least 8psi, otherwise it's just not worth all the labor.
