Turbo my B16 CRX..
Old Dec 14, 2003 | 12:17 PM
Tribusracing's Avatar
Default Turbo my B16 CRX..
Hey Guys
I have a B16 in my crx, all stock internals..some bolt ons..
I want to turbo the crx now. I want to know how much can I boost on the stock motor before it starts messing up the motor?
Also I want to know what size intercooler and size turbo should I run??
I want to get some decent power out of the car.. Let me know.. Thanks in advance
Old Dec 14, 2003 | 12:26 PM
StreetDriven's Avatar
I <3 your mom
it all depends on how much you spend on tuning the car plus what kind of fuel mag. you have have on it. I would say things would be fine at 8psi give or take. I have seen some motors hold over 18 with thicker head gasket but yet again its all in the guy that is working on the motor
Old Dec 14, 2003 | 12:31 PM
99B16Si's Avatar
generally speaking, a stock b16 motor with a bolt on turbo kit will be ok at about 7-8psi with the provided fmu and fuel pump. if u upgrade the fuel system u can get away with 10psi for quite a while. too much timing will eat away at the life of your motor also, so make sure that its conservative
Old Dec 14, 2003 | 12:39 PM
Alpha's Avatar
You will be fine on stock internals provided you get some sort of management (Hondata, AEM EMS, FAST), larger injectors and some good tuning. With that done you should be able to push 280whp safely. I would recommend a T3/T04E 50 trim with a .48 A/R turbine or if you have an extra $150.00 - $200.00 a Precision SC50.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 14, 2003 | 01:27 PM
Hey guys,
I know a guys that has a
Vortec 12:1 FMU
Venom Fuel Pump
and RC 440 injectors.. will that be enought fuel to go to the motor??
Old Dec 14, 2003 | 01:31 PM
Alpha's Avatar
Honestly I would ditch the FMU for Hondata or at least an Apexi VAFC.
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 14, 2003 | 01:42 PM
Hey
Oh you dont need to run the FMU??
I thought you had to run it
I heard that the JG Edelbrock intake manifold is a good manifold to run for turbo.. is that true or should I just stay with stock??
Thanks again for the help guys.
Old Dec 14, 2003 | 05:10 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
It's a goog mani.
Old Dec 14, 2003 | 05:16 PM
Suspect's Avatar
Certified since '85
How much power would put down probably runnin 8-10lbs of boost
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
Old Dec 14, 2003 | 05:33 PM
Hey
So run the JG over the stock?
Will it make better numbers then the stock??
Thanks
