Oxygen content problem?
Old Nov 22, 2003 | 07:27 AM
getrdun's Avatar
"Lucky"
Default Oxygen content problem?
Occassionally my strong running motor throws an O2 content code. I have a bone stock SIRII (JDM B16A).
-The condition always happens under heavy to full load.
-it ususally only happens up hills, on a full tank, or when the ac is on.
-last time I looked, my plugs where near the leaner side, but showed no sign of detonation.
-It seems to happen more when I run my cold air intake.
-Timing ignition/cam are both stock.
Any suggestions on what to check are greatly appreciated.
I have not had a whole lot of time to sit there and try to diagnose what the possible issues could be.
Thanks in advance.
-Neil
"Thou shall not weave in and out of traffic." -The 11th Demandment
Old Nov 22, 2003 | 08:25 AM
quicksilver EK's Avatar
The one punch machine gun
Kenji Chip in that ECU of your will fix that bye bye codes.
P.S. ill be back in Tampa on Dec 2 ill give you a call hope you ready for some tennis
97 ITR-Mugen Equiped
04 Honda 600RR
Old Nov 22, 2003 | 08:27 AM
getrdun's Avatar
"Lucky"
The tennis sounds good Steve, but I like my codes. One day they might save me from a major engine issue.
Old Nov 23, 2003 | 05:27 PM
mtber's Avatar
What makes you think you have oxygen issues ?
What codes do you throw ?
Old Nov 24, 2003 | 07:17 PM
getrdun's Avatar
"Lucky"
I throw code "1," which is O2 content, if I remember correctly. I have now had a chance to check my plugs, they look great, actually they are a little black on the bottom of the porcelin(sp). I have never been quite positive of what a perfect example of a plug looks like. If I remeber correctly, it should have a little brownish-grey look. Am I right?
Old Nov 25, 2003 | 06:40 AM
mtber's Avatar
If you are throwing code one (Oxygen Sensor)
Get a voltmeter & a haynes or helms manual & test you're oxygen sensor
If it is bad replace it & go from there.
Old Nov 25, 2003 | 07:14 AM
crix's Avatar
:mugen member:
check the intake air temp-sensor as well
it will set a code -1.........too
Old Nov 26, 2003 | 04:44 AM
getrdun's Avatar
"Lucky"
Thanks Crix!
Mtber,
Code one for my car is o2 content. There is seperate codes for O2 sensors, but thanks for your help. Oh and I have checked the O2, when this was happenig before and it was fine.
Old Nov 26, 2003 | 07:59 AM
mtber's Avatar
All you needed to say is that you new for a fact that you had a good 02 sensor installed
