hard start up
i have a 95 civic with b18b1. ever sence i change the tranny on the motor it gives me problem starting up(takes about 4-5 turnovers befor car starts) in the morning or if i let my car sit for about 3hr.i had it dignose and code 6 and 10 shows up. saying my coolant temp sensor volt is high (code 6),and intake air temp sensor volt is high(code 10).
what does that mean do i have a bad ground.i dont think i do cause i plug every thing the same way.would that cause me the start up rough. i am run a 93 intgera ecu.
CAN SOMEONE PLEASE HELP ME.
I had the same problem with my 92 civic hatch but only code 6 for the coolant temp sensor, I bought a new one and it still took a while for it to actually run normal. I had a water temp guage that was wrongly hooked up and when i disconnectted it the problem went away, so if you have that guage check the wirring if not sorry cant help you.
Janky Crew Productions
