running rich
1990 Civic 4dr
Stock fuel pump
310 injectors
Stock b16
Timing TDC
Looking for somthing that will stop the car from running so rich.
Thanks
Stock fuel pump
310 injectors
Stock b16
Timing TDC
Thanks
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
The Motor is from a 2000 Si.
The stock injectors for that motor are saturated and I needed Peak and Hold (could have that backwards). So I got those for 100 brand new. Couldn't pass that up. I'm working on a turbo setup so they will be use full later.
Right now I would just like to cut down on all the wasted fuel, without changing the injectors unless I have too.
I'm working alot right now. I'll try to make it to one of the test and tunes. I'll let you know.
