anyone using skunk2 upper control arms
just wanting to know if anyone is currently running the skunk2 upper controla arm camber kit and how it is working for them IE: easy to use, does it come loose? or does it work worth a damn, i need more negative camber for the road coarses.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
works great for me never came loose and very easy to adjust
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
Originally posted by Echo7847
I've got them also. If you're dropped too low the arm will scrape/hit the inner upper fenderwell as its larger than the factory unit.
Anyways, ya, I'm running the Skunk2 upper arms. They're good but I've seen documentation of them slipping under heavy track use. There is also a tendency for the balljoint, at least in the earlier models, to fail. This isn't too big an issue anymore since Skunk2 has finally begun offering balljoint replacements (used to be hell to get a hold of one). With that said, I've been running the camber kit for about two years (maybe a little less) and have quite a few autocrosses on them. So far there isn't even a bit of slippage and the balljoints are still in great shape.
