F22 Swap
I agree with all above statments. Why the hell would you do that??? The H series is far better that any F series ever will be. However, the H22 doesn't handle boost well! At least that's what I've heard!
F22 SOHC Non-Vtec Turbo
I plan on running (2) Fuel pumps
Greddy Boost gauge
Apexi turbo Timer
Hks 1,000 cc/min injectors
Tial Wastegate
Drag Iron Turbo Manifold
T4/t3 Hybrid(.60/.63ar 50trim Stage 3 wheel ported housing)
Hondata Stage 2b
Oil cooler
HKS FMIC and custom piping
The Block is complete:
Golden Eagle Sleeves 87mm Bore
Crower Billet Rods I-Beam Series
XT Pistons 8.8:1
High flow Prodrive Oil Pump
Modified Water Pump
The head is in progress.(Still doing research)
VALVES (5 angle valve job)
Stainless Steel Heat treated black nitrided .05 oversized Valves
KMS Titanium Retainers and Springs
Port and Pollish
Custom intake manifold
AEM Cam Gear
SkunkII Stage II Cam
70mm Trottle Body
Greddy Boost gauge
Apexi turbo Timer
Tial Wastegate
Hondata Stage 2b
Oil cooler
XT Pistons 8.8:1
Modified Water Pump
Port and Pollish
AEM Cam Gear
70mm Trottle Body
