integra master cylinder in an EG?
Old Nov 10, 2003 | 07:14 AM
NChatch's Avatar
i stepped on my weiner!
Default integra master cylinder in an EG?
will a gsr integra master cylinder bolt up in an EG, and if so, do you need the brake booster thing? i wanna try to get a little more stoppiong power out of my factory front and rear discs, but i wanted to know if this would help? i ask because mine is going bad and if it helps then kick ass
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Nov 10, 2003 | 08:18 AM
pressuredsol's Avatar
Pleasure the do me
You do need the brake booster I believe. Yes, it does bolt up, my friend had one in an EF. A little bit of a difference.
Old Nov 10, 2003 | 08:45 AM
CXHatchback's Avatar
Currently Ballin'
Does your hatch have abs?
Old Nov 10, 2003 | 02:36 PM
NChatch's Avatar
no my hatch doesnt have ABS, its a canadian model, i already have power slots front and back but i want a little more stopping power, so where does anyone suggest a brake booster from?
owner/operator
Old Nov 10, 2003 | 03:53 PM
Spence's Avatar
"TEAM WHITEY"
Hey nc get a teg booster and mc and you should be good takes about a 1/2 day man
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Nov 10, 2003 | 04:21 PM
MRFreeze's Avatar
Organ Donor
On the Civic MC, both brake likes bolt into it on the same side (driver side). On the Integra 1" MC, one line bolts in on the driver side and the other bolts in on the passenger side. If you want to use it, you will need the Integra booster and you will need to either acquire the correct Integra hard line or learn how to cut and flare the line that is already on your car. If you would rather not mess with all that, you can get a Civic EX w/abs or del Sol VTEC w/abs MC. As far as I know, it will bolt up to any other 5th gen civic booster and it uses the OEM civic mounting points (both on the driver side). That MC is 15/16". Nearly as big as the Integra MC. I doubt you will notice the difference. If you are buying it new, it's cheaper too. It is advisable to get the matching Booster. There is a noticeable difference in pedal effort.
FYI on MC sizes to the best of my knowledge:
Civic CX, DX, VX, del Sol S = 13/16th"
Civic Si(92-95), Ex, del Sol Si, VTEC= 7/8"
Civic models w/abs, del Sol VTEC w/abs = 15/16"
Integra (all) = 1"
94 del Sol VTEC
09 TSX
Old Nov 10, 2003 | 06:05 PM
Spence's Avatar
"TEAM WHITEY"
Nc if you need a adapter make sure you remember AMAZON!!!!
Old Nov 11, 2003 | 06:06 AM
NChatch's Avatar
thanks guys i appreciate all the grat info, i am gonna look for both of the master cyclinders and price em, but can you buy the booster from a parts store or do i need to find me a junked integra?
owner/operator
Old Nov 11, 2003 | 03:56 PM
Bill's Avatar
Livin' in Seattle
Don't forget the prop valve. I went with the Si valve since it doesn't have ABS but since you're in an EG you'll probably need the RS prop valve.
Oh, and if you want to save yourself some work, get a 98+ MC. You won't have to reflare your lines to work with the MC and all that is required is some slight bending of the lines. Plus...they're all 1" bores I believe.
Old Nov 11, 2003 | 04:42 PM
Spence's Avatar
"TEAM WHITEY"
mc go to ace they have allyou want and the pv you dont need since you have a si i used a si pv on my car and brakes on a dime man
