Diffs. between the b18a and b18b?
Originally posted by Cronic
I believe it's basicly, intake cam, intake manifold, and ecu mapping.
94-01 integras use b18b1 as the engine code..94-95 Integras use an 0BD1 P75 ECU and 92-93 use an OBD1 PR4 ECU...
b18a1 engines have an Oil/Water Cooler in between the engine block and the oil filter...b18b1 engines do not...
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
My b18a does not have an oil/ater heat exhanger, afaik, only some b16's had em?
When i was building up my motor, i put a b18b head on a b18a shortblock, there were a few extra/lacking water ports. 94-95 have more ignition advance than 92-93, so I believe that accounts for the extra 2hp.
Zee
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
Originally posted by Sunrise City Rider
Are you the original owner of the b18a? b18a's have the same oil cooler as the b16a's...
Zee
Zee
Well the b18a blocks are the prefered choice when doing an LSVtec Buildup as some of them come with the Oil/Water Cooler...
Zee
Zee
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
