----Have a question about blockguards------
Im curently building a motor. But for now I wanted to see if i could but a blockguard on a ls block..and run some boost with nos??? The block will have eagle rods and je pistons..Would the motor last with me runing like 13-18psi and a 100 shot or more.
Would it hold up with just nos???Or can I throw my turbo kit on it too?? So my question really is can i make high hourse power on a blockguard?????
Thanks Darren
Thanks Darren
fuck no. you might a few passes on lets say 15psi and a 100 shot. thats assuming it managed to get tuned on that without blowing up. youll need some after market sleeves and valves to hold all that boost and nitrous consistantly.
The head has aftermarket valves...Could I just go nos..With the blockguard??? I know someone who has a ls motor runing 18psi and a 100 shot and runs 11's in a hatch..But hes crazy..I would be happy just spraying nos..If I was just going to spray on it..How much would i be able to spray?? I know I can spray 100 cause I've seen people spraying 100 on stock blocks..
someone awhile back posted that they ran a 150 wet shot on their stock gsr and went threw 30 bottles before problems...worn piston rings... If you got some decent piston rings and good tuning it will last but for how long is up to how much you beat on it....
don't listen to him he's stearing you in the wrong direction you've got to use six (6) so you get total reanforcement on those umm cylinder walls yeh! thats it .... then you've got to rent a jackhammer from your local rent-all and also on your way home slide by Sams club and get the biggest fucking tub of CRISCO you can cause you will need it to get the freakin blockgaurd in GOOD LUCK
MONEY TALKS BUT "CASH SCREAMS"!
