need info on wiring vtec to a switch
Old Oct 19, 2003 | 05:51 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
Question need info on wiring vtec to a switch
my boy has a 90 civic hatch with a B16A.... not too long ago his ecu was stolen and he is stuck using the stock ecu wich does not open vtec... i was wondering how hard it would be and if anyone knows how to wire his vtec to a switch temporarily until he can get the funds to buy the PR3........ the car runs fine but is severely lackin without vtec... if anyone knows how to do this please IM me on AOL at importmayhem1@aol.com or if anyone knows a link to a website where i can get a diagram to do this please send it to me via email or private message... thank you
CHRIS
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Oct 19, 2003 | 06:07 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
I could be wrng, but that doesn't seem practical or possible. Tell him to call one of the many shops or junkyards around here and find an ECU.
Old Oct 19, 2003 | 06:10 PM
Retired Ricer...
the non obd b series vtec ecu's are nearly impossible to find right now and when u do find them they want way too much.... i know a few people that have vtec wired directly to a switch and it worked fine but like i said this is just a temporary fix until he has the money to buy the ecu......
Old Oct 19, 2003 | 06:17 PM
well, sounds weird to me, but good luck. I'm sure if it can be done one of our Honda genuises will know how to do it.
Old Oct 19, 2003 | 06:19 PM
civicracer901's Avatar
B16ACRX
you can just run it off one of the relays up buy your headlights. Or just buy a relay. Its really easy. Buy a toggle switch run the wire and your done. Switch it one whenever. Two wires total.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Oct 19, 2003 | 06:22 PM
B16ACRX
acuttaly forgot, one also come from the VTS. So you have the VTS wire ran to the relay and then from the relay to the switch from wherever you seat it.
Old Oct 19, 2003 | 06:29 PM
Retired Ricer...
ok im lost is there anyway u could explain that better.... i get the relay thing and all that but where to run the wires and everything im kinda lost... if ur on aim or aol hit me up on importmayhem1@aol.com... thanks chris
Old Oct 19, 2003 | 07:01 PM
BitbyStreetRacin's Avatar
once your bit, your done.
MSD rpm activatd switch is for that isnt it?
Old Oct 19, 2003 | 07:12 PM
Retired Ricer...
im not sure u can use it without the MSD box... although thats mainly for shift lights etc., now that u mention it it sounds like it should work... thats a good idea... might have to try that
Old Oct 19, 2003 | 07:48 PM
KJ's Avatar
KJ
bored at work
Don't do this. The stock ecu will run it lean in vtec (if you run a switch), maybe a little too lean and your friend will have to end up replacing a motor along with an ecu. Do it right with an ecu or don't do it at all.
If you need an ecu try contacting:
Joe Locash of locash racing, www.locahracing.com
or
Kenji Plennert
kenji211@tampabay.rr.com
Both deal in alot of ecu's. Not sure if Kenji has any pr3's or pw0's laying around but Joe probably does.
