Replacing Cam Seals?
Old Oct 15, 2003 | 07:57 AM
quickcivic's Avatar
addicted to boost
Default Replacing Cam Seals?
Who here has replaced their cam seals?
Mine are leaking and I have never replaced them before and was going to try and replace them tonight myself, since money is very tight right now.
I went to Acura and purchased the seals (with new valve cover gasket and spark plug seals). If anyone can offer any advice or help, I would appreciate it.
Thanks
Old Oct 15, 2003 | 08:12 AM
99B16Si's Avatar
very easy process. but unfortunately u need to remove the cams and timing belt. just make sure u have silicone and a timing light. shouldnt take longer than 30 minutes to an hour at the most. let me know if u need help, goodluck
Old Oct 15, 2003 | 08:49 AM
chi town brat's Avatar
! Ne shab'rud'ni !
I did mine with David on my SOHC. What was nice is he made a mig shift seal puller. So we didn't have to remove the cam. Since he was instructing me it took about an hour to hour and a half. I didn't find it hard.
Old Oct 15, 2003 | 09:47 AM
99B16Si's Avatar
then how do u plan on getting the timing side seals off????? the long "trays"(I dont know the real name for them) run completely across the cams and hold down all the caps. therefore u cant take off the caps without unbolting those trays, which hold the cams down. goodluck changing your seals with the cams still in.
Old Oct 15, 2003 | 09:57 AM
99B16Si's Avatar
u may be able to squeeze them out without removing the cam but either way, the cam gears need to come off, and so does the timing belt because of that, which is the more complicated part...the rest is just bolts
Old Oct 15, 2003 | 11:03 AM
99B16Si's Avatar
yea maybe, where/which of your seals are leaking?
Old Oct 15, 2003 | 11:14 AM
quickcivic's Avatar
addicted to boost
I'm talking about the cam gear side. The dist. side is fine.
Where do you buy Hondabond?
