pinging !!!!!
Old Sep 18, 2003 | 04:23 AM
Doc Brown's Avatar
too much, is just enough
Default pinging !!!!!
i just got my car tuned last friday. he advance my ingintion to 17 degrees. if i give it gas at low rpm below 2,000 it will sometimes pinp. but though out the power band it doesn't. i have an accord euro r mani and the iacv went bad on it. so i just zip tied a h22 to the fire wall and pluged it in so i would stop thoughin the code. do you think that because it is not bolted it up to the mani that could be why i am pinping? i realy don't want to have to back down my timing across the power band because of this. but if i have i will
????? on the way
Old Sep 18, 2003 | 05:11 AM
KJ's Avatar
KJ
bored at work
Just back it down a couple degrees I guess. Did you try adding fuel down low?
Old Sep 18, 2003 | 05:14 AM
Doc Brown's Avatar
Originally posted by Cronic
That detonation can't be good for your pistons.
very true.
yes i am using 93. Glen tuned my car at hybrid performance. i was afriad that was what you were going to say.
so you think that iacv has nothing to do with. i am making a adptor plate for it so it will be on there soon.
????? on the way
Old Sep 18, 2003 | 05:21 AM
Doc Brown's Avatar
thanx alot. i would like to get hondata but i don' have money coming out of my ass. and it is 2 times as much to get it tuned. but i guess it is worth it. i will just have to work a little harder. bvy the way which hondata unit should i get. and about how much does it run ?
KJ. when do you think i can bring my car by to get the timing changed, and to look at my dizzy to see if we can get my tecks to work. let me know thanx
????? on the way
Old Sep 18, 2003 | 10:01 AM
Sunrise City Rider's Avatar
WHAT!?! OK!......
Bump up the fuel pressure if you don't want to retard the timing...Run 93 as you have been doing and make sure the fuel system is clean...If you knock the timing back a degree, you will not notice any change in power as your motor is mild and the detonation on cast pistons can lead to damage in short time...
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
