what wold be better
The K20a has valves that dwarf the b-series valves, the valvetrain is stable to over 9,000rpm stock, the timing belt system is replaced with a timing chain, the oil pump has its own dedicated gears and chain, the VTC system take VTEC into a whole other level...Imagine being able to change intake cam timing as your rpm and throttle position changes...This is what makes the K20a much more effiecient and you don't know fast until you try to shift a 450whp RSX Type S while holding onto its small diameter wheel...
I have never been intimidated by a car's power before until I felt the surge of power on the Cybernation's RSX shop car while behind the wheel with instructions from the owner to drive it like I stole it...
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
Zee
Zee
Originally posted by MattC
i'm not a big fan of the k-series motor, i'd stick to b-series, more technology for them at the moment, and much cheaper.
2012 FIAT 500 ABARTH
Originally posted by racethis001
i was thinking of swapping it into a 98 teg.
