Air, Fuel, and Spark, OH MY!
Old Sep 2, 2003 | 02:59 PM
BitbyStreetRacin's Avatar
once your bit, your done.
im gonna try it. last hope.
when im trying to start it, is the cam supposed to turn really slow?
Old Sep 2, 2003 | 03:14 PM
ok, that didnt work either. im pissed. ready to sell the car now.
fuckin had a perfect push start goin, then when i dump the clutch, the piece of shit didnt even sound like it wanted to start.
key was on, 1st gear, etc. etc. what the fuck is there left to do?
Old Sep 2, 2003 | 06:05 PM
bumpity bump
Old Sep 3, 2003 | 04:19 AM
Old Sep 3, 2003 | 11:54 AM
  #17 (permalink)
chi town brat's Avatar
! Ne shab'rud'ni !
my simple guess...did you blow the ecu fuse? simple check.
Old Sep 3, 2003 | 04:51 PM
  #18 (permalink)
Cronic: it all started when i fucked with the pgm-fi main relay. i will try leaving the hose off to see if it squirts.... if the key is on the ON position, will the fuel keep squirting or will it just burst a little then stop? When i cracked open the bolt at the end of the rail, it sorta just spurted out from pressure. i dont know if this is good or bad. and yes i hear the fuel pump...i think. sounds like a dentist tooth drill far away right? ill let you know what happens when i try that. thanks for the advice.
chi town: yea, i replaced it about 20 times, but currently the ECU fuse is good =/
when i used to turn the key to the ON position, something beeped a few times kinda loud. maybe the ECU or maybe the RPM activated switch. but whatever it is, it doesnt do it anymore, what does anyone think that is?
also, when the key is in the ON position, what should the ECU light be doing? mine stays steady.....that may be bad?
when the car used to run, the code was like: 1, 16, 1, 16 etc. what is that code for?
Old Sep 4, 2003 | 05:17 AM
  #19 (permalink)
