Please Help!!!!!!
you should check timing did you set your tps sensor that could be off as well def. need a map sensor and fuel pressure i have the same motor in my crx let me know if i can help its me paul from brandon
if you point the gun at the cams, the light should flash at exactly the point where the timing marks are together...You can't tell how far off your timing is without the lower cover...
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
