Injector question????
Old Aug 25, 2003 | 09:57 AM
T61turboII's Avatar
Default Injector question????
I would like to know if rx-7 460cc injectors can be used on a 94 gsr motor. im boosting so i need bigger injectors.i check the ohm reading on the injectors and there at bout 13-13.5 will that compatable for the gsr or is it to high.. If those wont fit please tell me what i can use...thanx
Old Aug 25, 2003 | 10:25 AM
T61turboII's Avatar
Thanx for the info... The dsm injectors i need is it from a turbo or non turbo that i need...
Old Aug 25, 2003 | 12:34 PM
psifactor's Avatar
Hello
I'm not sure if they are going to work on your car. It all depends on if you have a resistor box making your low impedance injectors high.
since the injectors in your car are 13-15ohms seems like you would have to add a resistor box to make low impedance injectors work. And I'm not sure if that can be done. you are able to find high impedance rx7 550cc injectors easily.
that may be the easier route to go.
Heavy car with a 2.5L
