Stroked Motor Build Up
Guest
Posts: n/a
10.5 is abou the limit for FI (turbo/supercharger) Ive heard of people spraying with 12:1 compression before, although I don't wanna say that's safe.
Tuning would be the key with this motor. Thanks once again KJ.
IMHO: I don't see too much of an advantage with this motor.
Originally posted by Cronic
What rods would he use? What would the R/S be on that setup? What pistons should he use?
Don't say you're done when you've just begun!
Rods-Pistons are you going to use?
Im The Original Crab!
R/S Ratio would not be a problem, that is why you use a stock GSR crank.
I would use Golden Eagle Sleeves, Wiseco Pistons and Crower Rods. Stock GSR head.
You better get HONDATA.
Now can I be done?
Now can I be done?
gsr crank would have to use gsr or type r rods. R/S would be 1.58/1
B16A can be bored to 84.5, and you could use a B17A crank. It would bring you to 1.8L. B17A rods will give you a r/s of 1.68/1 and would be your only choice other than aftermarket. Although the old prelude(B20A) might have rods near the same length and they should have the same size big end.
For 84.5mm pistons aftermarket is your only option.
You'd use GSR rods rods w/ a gsr crank.
Gracie Barra Clearwater
