88 teg motor to 91 hatch
Originally Posted by alri0085
I know the answer because I put a d16a1 in my 89 crx si.
The motor will fit, but this is what i had to do:
1. tranny and block only match 4 out of 5 bolts, but still works.
2. CYL sensor needs to be rewired, and the distributor plug needs to be modified to fit the A1 distributor also.
3. 2 vacuum lines need to be sealed.
4. I only had 3 motor mounts, no driver's side mount.
5. no knock sensor on A1 block, so no need to hook that up.
That's all, and the engine fits and runs great, BUT here's what happened with the motor running:
1. raced a del sol non-vtec and I lost.
2. after that, I turboed it and 7PSIs blew valve seals.
3. rebuilt head after that.
4. after 395 miles with this motor, It threw a rod.
In conclution, the motor will work, but it has NO potential as a high HP motor, no potential, did I mention no potential?
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
heheh knocksensor huh,blow a valve seal huh,so your saying the rear mount lined up right with a stock mount
i love AUTOZONE
i love AUTOZONE
Originally Posted by Hybrid_eg
You put a motor in without a drivers-side mount? And it STAYED in the engine bay??
all the side weight was on the front and rear mounts, you you can imagine how messed up those mounts got.
. You with me on this one Rang?
Shut yo ass up nugguh..
ReginaVagina
ReginaVagina
yes cause i have seen some try this and there was alot of work done and still looked like shit..like for one you say you turboed it how the hell you going to turbo it with it hummping around in there.what manifold did you use?crank pullie? take some picture then you get my vote
i love AUTOZONE
i love AUTOZONE
where's my vote now! and I want some rep points too
no motor mount at all. sorry for the quality of the pictures, I took them with my camera phone. BTW I now have a DOHC ZC in the crx.
