AEM Air Bypass Valve
Old Jul 26, 2003 | 09:18 AM
djcrx456's Avatar
Default AEM Air Bypass Valve
I just bought a cold air intake off of Ebay. ( Dirt cheap not to mention I'm on a budget ). To play it safe I want to buy an air bypass valve. My question is, what do I connect the bypass valve to? The bottom of the intake where the filter is, the middle because it is a 2 piece pipping cold air, or right next to the TB. Any help would be appreciated.
Thanks David
Old Jul 26, 2003 | 09:20 AM
HKSWRX's Avatar
Rraawwrr!!
right after the filter i would imagine
www.myspace.com/beyondthemire
Old Jul 26, 2003 | 09:29 AM
djcrx456's Avatar
Sweet, anyone know for sure ?
Old Jul 26, 2003 | 10:38 AM
mike34655's Avatar
Member
I would say in the middle. You dont want it next to the filter because it you go through a deep puddle the bypass valve will be under water too. If you put it in the middle (between the 2 pieces) then it will be away from the water.
Old Jul 26, 2003 | 10:39 AM
mike34655's Avatar
Member
Thats where I would place it and isn't the whole purpose of it to protect the engine from water?
Old Jul 26, 2003 | 10:43 AM
CiViCBoY's Avatar
Lamer
The middle for sure
Old Jul 26, 2003 | 10:50 AM
HKSWRX's Avatar
Rraawwrr!!
yeah i didnt think about that, good thought fellas =)
Old Jul 26, 2003 | 11:04 AM
djcrx456's Avatar
Thanks for the help guys, Civic Boy are you laughing because the thought of putting it by the filter, or are you not supposed to put it in the middle ?
Old Jul 26, 2003 | 11:11 AM
Ralph's Avatar
TR Balla Donor Supreme
Actually I think the bypass valve is designed to only work when fully submerged under water. So putting after the filter is probaly your better solution(assuming thats how its SUPPOSED to work..check out AEM's site to make sure).
TR Profile
Myspace Profile
Old Jul 26, 2003 | 11:20 AM
mike34655's Avatar
Member
No the Bypass valve is suppose to work when the filter is submerged under water. If the bypass valve is under water then your engine is going to be sucking in water.
