Guns & Ammo Guns, Ammo, Knives, Weapons.. etc..
A Little Advice from Concealed Carry Magazine Senior Editor Ed Combs
Old Aug 31, 2018 | 12:16 PM
Default A Little Advice from Concealed Carry Magazine Senior Editor Ed Combs
BY TIM SCHMIDT - USCCA FOUNDER Things have been rough around here for the last week or so. Strong storms and record rainfall in many counties have prompted Governor Scott Walker to declare a state of emergency in Wisconsin. While the USCCA Headquarters has been spared the brunt of severe weather, several employees have had to find new ways to get to work because of fallen trees and washed-out roads. In some parts of the state, entire neighborhoods are underwater. I even read a story about a young boy who almost got washed away while playing in floodwaters just south of here. Scary stuff.
Anyway, I recalled that around this same time last year (flood season in the Midwest and hurricane season in other locations), I asked Concealed Carry Magazine Senior Editor Ed Combs to lend his expertise to the topic. He conveyed some great and timely advice that I thought was worth sharing again. Here's what Ed had to say:
Hurricanes and floods — and the chaos they always bring — can serve as stark reminders of why our Second Amendment rights are so important. Your firearms allow you to secure your family and your property as you get to safety, and when law enforcement is occupied with other matters, you're often required to do just that.
After the flood waters recede and you're able to return to your home, the scene is often utter devastation. Though you were able to get yourself, your loved ones and your essential supplies out in time, often the rest of your residence and the property therein is soaked ... or worse. No firearm or cartridge was designed to spend days — or even minutes — underwater, and as you put your life back together, it will be imperative that you know how to handle any guns and ammunition that you were able to salvage from a flooded building.
WHAT'S THE BEST WAY TO DRY OUT GUNS?
As soon as you can, get the firearms disassembled and begin the process of drying them out. Separate metal parts from wood and polymer, and immediately begin soaking any metal components in some kind of penetrating oil. You're not looking to "get them dry" ... you're looking to completely coat every metal part in oil. Your main goal is to drive out any water that is currently hiding in the mechanism, so you should be more concerned with getting the water out and the oil in than with perfectly detail-stripping the firearm first. Don't forget though: The polymer frames of handguns do contain small steel components, and though you will likely have to replace those small steel components if they're already rusted in place, you still need to get oil up into and through the frames of any autos or revolvers. Err on the side of oily, and don't be stingy; if you can, submerge the stripped firearm in oil of some kind to really drive out any remaining water.
The aftermath of a disaster like this isn't the time to be overly picky either. Though I would normally never use WD-40 on a firearm (it can damage the primers in ammunition), if that's the only oil available and I just fished my Smith & Wesson Model 19 out of a flooded basement, you can bet I'll be liberally hosing it down with every dad's favorite fix-all. Again, the first priority is to convert your firearms from wet to oily, and even motor oil is better than nothing for accomplishing that. Everything else can be handled later.
Polymer components usually rebound very easily from being submerged, but wood stocks are not as lucky. Resist the temptation to use a hair dryer or a heat gun on your stocks, as this will almost certainly damage them. Begin the drying process slowly, and be prepared to recondition or replace them as they dry.
WHAT HAPPENS WHEN AMMUNITION GETS SUBMERGED FOR DAYS ON END?
If ammunition has been submerged for more than a few seconds, it should not be fired. Water getting into the cases could result in unreliability and unsafe pressures (both low and high), so the best course of action is to sell it as damaged ammunition to be broken down into its component parts for reuse or to do so yourself. The powder and the primer in a centerfire cartridge are unreliable and unsafe after being submerged, but the case (provided it is reloadable) and the projectile are still just fine. Selling or recycling that ammo at a steep loss will be cold comfort, but it will be far better than just dropping it all off at the police department, sheriff's office or fire station to be destroyed.
WHAT IF I GET HOME AND CAN'T GET MY SAFE OPEN?
If you return to your residence and are unable to open your safe, your best move will be to contact the manufacturer before doing anything else. If it is a mechanical safe, the manufacturer should be able to walk you through the steps to best access your firearms without inflicting additional damage on them. If it is an electronic unit, the same applies. Either way, you will quickly find out what the company policy is on flood damage.
If you decide to start extracting your guns from a safe that simply cannot be opened through conventional means, the key is to go slowly. Even an inexpensive Chinese angle grinder or cut-off wheel can get you through the sides or backs of most units, but remember that doing so will bring with it fire hazards from flying sparks and, of course, dangers to eyes, ears and fingers. Whatever you decide to do, proceed with caution. Don't lose sight of the fact that property is just that: property. It is only humans who cannot be replaced.
STAY SAFE, GOD BLESS
Floods cause massive disruptions in our lives and can destroy some of the things we hold the dearest, but even my most treasured guns are not as valuable as my loved ones. If you've been affected by any of the horrendous storms that have been flogging parts of this great nation, we here at the USCCA wish you nothing but the best and are here to answer any gun-related questions you might have.
Stay safe,
Ed Combs
Senior Editor
As Ed mentioned above, guns and ammo can be replaced; people cannot. Still, it is our sincere hope here at the USCCA that you're able to salvage whatever you can after the worst has passed.
Take care and stay safe,
Tim Schmidt
Publisher - Concealed Carry Report
USCCA Founder
Guns & Ammo
Jan 26, 2018 03:38 PM
Guns & Ammo
Sep 16, 2017 02:09 AM
Sep 25, 2014 01:00 PM
blacksheep-1
The Ford Forum Lounge
Jun 28, 2008 02:54 AM
