Will a C5 motor drop into z28
Old Feb 7, 2003 | 07:21 PM
HybridSS's Avatar
I have fuzzy eyebrows
The approx $2999 for the 375 motor includes a new block, JE pistons, Eagle rods, stock (not offset crank) and the rest. An entire shortblock ready to install . Not using any stock parts that may be on some ones motor already. You have a good block, crank and stock rods already to use. Of course it will be cheaper for you. Your just doing pistons, bearings, rings, etc.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Feb 8, 2003 | 05:32 AM
Country Boy's Avatar
can survive...
I dont have stock rods
How is he with cams? I might me calling him down the road?
Old Feb 11, 2003 | 11:01 AM
DinoZ's Avatar
Didn't Futral have the first cam only (stock heads) car in the 10's?
Also, Will, the oil pan has to be switched... the *** oil pan isn't compatible with the F-body underneath. So you can get an ***, change T/B and oil pan, and turn the key and go!
I drive way too fast to worry about cancer!!!
I eat Omni GLH-S's for breakfast!!!
Your fish smells like pussy!!!
