sbc timing
Old Oct 13, 2009 | 10:58 AM
sovlisky's Avatar
Default sbc timing
i was doing the timing chain and the crank moved when i was taking off the timing gear b4 i got to mark them now im stuck can anybody please help
Old Oct 13, 2009 | 02:01 PM
Mars_302's Avatar
Race Photographer
there should be marks on the new sprockets
Old Oct 14, 2009 | 08:41 AM
MTXaudioSYSTM's Avatar
Slow V6 Firebird
fail
Old Oct 14, 2009 | 12:22 PM
reiners88's Avatar
Heavy Chevy
if you have a aftermarket or a double roller chain there should be 3 marks on the cam gear. line the circle on the cam gear to 6 o clock and the crank to 12 o clock. hopefully it helps.
Old Oct 14, 2009 | 12:34 PM
impalamike3800's Avatar
3800 Guru
Originally Posted by MTXaudioSYSTM
fail
everyone has to start somewhere.
TRUE POWER DOESNT WHINE.... IT BLOWS!
Old Oct 14, 2009 | 05:07 PM
sovlisky's Avatar
now i cant get the gears with the chain on any advice????
Old Oct 14, 2009 | 05:25 PM
Mars_302's Avatar
Race Photographer
your supposed to put the crank sprocket on first, then wrap the chain around the cam sprocket then slide the cam sprocket on to the cam.
Old Oct 16, 2009 | 03:49 AM
fuelie327's Avatar
wow ...maybe you should start with oil changes
