Tranny mating to a 350 small block
Old Aug 10, 2009 | 06:07 PM
Buff2thekore's Avatar
Arrow Tranny mating to a 350 small block
ok, i have an 84 s10 pick up and i put an old 350 smal block from a 74 comaro in it. i hate automatic trannys but thats what came with the emgine so iv just been using it, but i have no idea about what 5-speed trannys can be converted to be used on my set up or what is supposed to be used. im going for a mechanical clutch cable delivery system, no hydrolic please, not enough room under the hood. Any help is nice, thanks.
Old Aug 11, 2009 | 04:39 AM
Default .....
i really want to get a 6 speed manual if i could guys, if someone could tell me how to make that happen id be happy as hell but just a 5 speed is cool too if there is no way possible due to splines and length of the in put shaft. id even find a way to put a master cylinder in for hydrolic clutch if i could go 6-speed.
Old Aug 11, 2009 | 04:53 AM
reiners88's Avatar
Heavy Chevy
im not too sure on how everything will fit but a T56 out of a LT1 camaro would work. problem being its hydraulic not mechanical like you want
Old Aug 11, 2009 | 05:00 AM
Default ....$
Is a t56 a 6-speed? Like would a tremec 6-speed work from a 01-04 vet?
Old Aug 11, 2009 | 12:55 PM
Z28ricer's Avatar
Doesnt see what you did
No a corvette one will not work, a 93-97 camaro / firebird one would be your best bet, you will need an aftermarket flywheel for your 2 piece rms crank, the shifter location is also further rearward than a T5 which was available in the S10.
You also make absolutely no sense saying you dont have room for a hydraulic master, but you somehow have room for manual linkage ? A Z bar setup is going to require a lot more room, and a lot more headache than a hydraulic master.
I have a world class T5 from a 92 camaro for sale if you are interested.
R.I.P. Tim
RB $200
LS1 $250
Old Aug 11, 2009 | 01:29 PM
Default hmmmmm
will that tranny in its current state bolt up to my 350? or will i need an adapter plate or a new bell housing?
Old Aug 11, 2009 | 08:10 PM
Z28ricer's Avatar
The T5 I have, with its bellhousing will bolt up with the belhousing (have it also), a 93-97 LT1 T56 will also bolt up, with the T56 you'll need an aftermarket 2 piece rms T56 flywheel, with the T5 you'll need a stock 2 piece rms flywheel, as the only one I have is for a 1 piece rms.
I also have a 94 or so S10 clutch master cylinder you can have free, whether you buy the trans or not, you may or may not be able to end up using it.
R.I.P. Tim
RB $200
LS1 $250
Old Aug 12, 2009 | 09:05 AM
Default ty
u r a man among men, ur very nice bro. could u locate a flywheel online that i could use so i know which direction im going in? and how much do u want for ur tranny?
Old Aug 15, 2009 | 06:08 PM
Default grrr...
that sux, u arnt replying....
