01' Camaro Problem
Old Dec 19, 2008 | 02:17 PM
Strunk's Avatar
Default 01' Camaro Problem
So the wife was driving home from work, About 10 miles into the drive the car stopped responding to the gas peddle and shut off about a min later. The car will crank for about 15 seconds then stalls. Any idea whats going on?
Its a 01 v6 5-speed.
Old Dec 19, 2008 | 09:31 PM
Sneakin Deacon's Avatar
PSSHHH x2
tps? throwing any codes?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Dec 28, 2008 | 02:05 AM
Jaysz28's Avatar
fuel pump
Old Jan 19, 2009 | 07:14 AM
rakoolo's Avatar
possible vats problem, I once was able to get the car started again by popping the hood and switching the starter relay with the ignition relay... it will start. could be a problem with the ecm, resistor chip in the key, vats module ?? very tough fix, needs a series of diagnosis
LiVn That Crazy Life Right
