LT-1 Sounds like a knock..........
Old Nov 14, 2008 | 10:22 AM
turboeclipse's Avatar
Adm1n1strat0r
Default LT-1 Sounds like a knock..........
i have a 94 LT-1 camaro, to me it sounds like a rod, but ive been told that some of the automatics break the flywheel adn while driving it "sounds like a rod knock" has anyone ever heard this before?
at engine start up around 1500-2000rpm itll sound like rod knock then go away and you only hear it around 2500-3000 just before a shift, if that helps any.
id like to know if this might be a possiblity before i but another engine and throw in it
(\___/)
(")__(")
This is Bunny.
Copy and paste bunny into your signature to help him gain world domination.
Old Nov 14, 2008 | 11:53 AM
J@meson's Avatar
Resident Ginger Kid...
well stop running the motor... if it is a rod knock your only going to damage the motor more by possibly throwing a rod, or oblonging the rod. yank the transmission out and check the flywheel. if its not damaged then atleast the trans is disconnected to pull the motor
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Nov 14, 2008 | 12:22 PM
Adm1n1strat0r
well thanks for going out of you way and NOT answering my question, i dont drive it, havnt since i first heard the noise, just getting options, but then again, the trans will need to be disconnected either way, so might as well get on it
but my question was, is what ive been told normal? has this happened to anyone else?
(\___/)
(")__(")
This is Bunny.
Old Nov 14, 2008 | 12:31 PM
Z28ricer's Avatar
Doesnt see what you did
Yes, i've witnessed a flexplate issue sound like rod knock, guy thought his engine was done, it wasnt.
Now do like he told you and go take it apart to find out, if you notice tq converter bolts loose, or the flexplate to crank bolts loose, or the flexplate broken, be happy, fix the issue and put it back together.
If not your a small way done with the beeeotch of removing a 4th gens engine.
R.I.P. Tim
RB $200
LS1 $250
Old Nov 14, 2008 | 12:32 PM
J@meson's Avatar
no its not normal, yes it has happened to me.
2003 Honda 954RR
Old Nov 14, 2008 | 12:36 PM
HeavyChevy3800's Avatar
405hp=SLOW
I broken flexplate will sound like rodnock at idle. But once you give it light throttle or hold the rpm's over 1000-1500rpm it will go away. Rodnock will obviously get louder with more load/rpm. If you do have rodnock there will most likely be metal shavings or gold flakes in the oil when you drain it. You can also inspect the flexplate by getting under the car and taking off the inspection cover. Look for damage while somone turns the motor over via the crank bolt.
Old Nov 14, 2008 | 02:43 PM
Adm1n1strat0r
thanks for the information guys ill take a look at it tomorrow if i get some spare time and report my findings
(\___/)
(")__(")
This is Bunny.
