Knocking LT1?
Old May 11, 2007 | 10:45 AM
  #41 (permalink)
Sneakin Deacon's Avatar
PSSHHH x2
Originally Posted by dalinkwent05871
any body actually seen what they look like?? these are on napa's site. I called another napa store and they said they are available but wouldnt be here til mid next week.. they are priced at about $120 each... is that justice?
...its napa...what were you expecting?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old May 11, 2007 | 11:00 AM
  #42 (permalink)
dalinkwent05871's Avatar
what are these?? i found these and im guessing its just the rubber inserts...
Spohn Performance, Inc.
also i called the dealer and they said they could have them usually next day and thier asking $112 for each...
Old May 11, 2007 | 11:05 AM
  #43 (permalink)
myltwon's Avatar
Bolt-On 2v GT
those are polyurethane mounts, much better than stock rubber
Old May 11, 2007 | 11:17 AM
  #44 (permalink)
would you use those with metal brackets that are holding my stock rubbers in now? if my metal brackets are in good shape all I would have to get are those?? or would i have to get some custom made brackets to hold those motor mount bushings?
Old May 14, 2007 | 09:57 AM
  #45 (permalink)
any one know if the mounts for lt1 was the same on z28? found some z28 mounts real cheap and was told they are the same. wholeseller.....
Old May 14, 2007 | 07:03 PM
  #46 (permalink)
TURACE24's Avatar
FYI you can eat up a flexplate from the center hub connection to the flywheel. With the trans on you will never notice it. If the mounts dont fix it, back to square 1.
  #47 (permalink)
TURACE24's Avatar
by the way check advance auto parts, and autozone, many times the parts stores will match prices to keep your business.
