Car overheated today...Thermostat sticking???
Old Dec 19, 2006 | 01:40 PM
dalinkwent05871's Avatar
my lt1 one has a constant problem of overheating. tried all kinds of different, so called tricks, to get it cooler but in the summer its just to hot. heard drilling holes in thermostat would allow the water to flow better to keep engine cooler.... didnt work as planned..... also grounded one of the fans so it turns on as soon as the key is in the on position... that does help a lot... but i wish i could keep it cool without all the "tricks". eliminated the system that hooks up to my exhaust manifold and reuses the exhaust back in the heads to heat the car up sooner in the morning.... but still just today.. it gets a lil hot outside and my car stays above 220, reaches 250 then thermostat opens and goes back down to 220.. is that normal?
Old Dec 19, 2006 | 02:06 PM
Sneakin Deacon's Avatar
PSSHHH x2
considering aluminum warps right around 250+ degrees...and you have aluminum heads...they dont sell a 250* thermostat for LT1's. so no...its not normal. your thermostat is 160 or 180 degree opening point.
you have air in your lines. you need to un ghetto rig all the crap you did, and bleed the system correctly and work from there. dont compound your problem with band aids.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Dec 19, 2006 | 07:49 PM
???'s Avatar
Capt."Howling Mad"Murdock
what he said... lt1s are picky about how you fill them
also, sometimes i've seen older cars just need a new radiator from having some much build up shit keep it from cooling the water. i think shops can clean them for you but most of the time we would just throw a new auto parts store one in and it cooled just find.
also a new radiator cap is cheap and it may be as simple as that.
Old Dec 20, 2006 | 07:38 AM
F*r*a*n*k*e*i's Avatar
Originally Posted by myltwon
or you have air in your lines
to test the thermo take it out and put it in a pot of water on your stove, set the stove to 180o if the thermo does not open then it's the t-stat, I'd say it's worth a shot to check it out since last I heard LS1 thermos were in the range of 35-40 dollars
If you're going to take the stat out, just replace it. Who the fuck boils their thermostats?
Old Dec 20, 2006 | 08:12 AM
my lines can have no air in them and still get to hot... i was thinking about getting the electric water pump soon. i know how to open the two air release valves so there is no air in the lines... my radiator cap is new... water pump is about a year old now.. and as far as i know the radiator itself has never been touched... the only ghetto i have rigged up now the fan turned on all the time which isnt any thing that can hurt the cooling of the engine. fan cld go bad sooner.. thats all. i didnt know thermostats were only about 50 bucks. i think ill go pick one up....
Old Dec 20, 2006 | 10:14 AM
PSSHHH x2
if you've done all that stuff correctly, go flush your cooling system...and just incase ya didnt know...DO NOT use dexcool.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Dec 20, 2006 | 07:30 PM
  #17 (permalink)
???'s Avatar
i'm going to say just replace the radiator, or atleast take it to a radiator shop and have them clean it.
i've seen it work more than once.
Old Dec 21, 2006 | 07:46 AM
  #18 (permalink)
myltwon's Avatar
Bolt-On 2v GT
when the thermostat for his car costs $50, I'd say it's worth a few minutes of my time
Old Dec 21, 2006 | 08:27 AM
  #19 (permalink)
BAMF's Avatar
Thread TERRORIST
250 is high for it to ever reach, but remember that GM had those goddamn F-Bodies running so hot from the factory it makes people think they have an overheating problem when they in fact don't. If I recall some of the F-Bodies went up to ~235 before the fans kicked on and brought it back down.
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Dec 21, 2006 | 10:25 AM
  #20 (permalink)
PSSHHH x2
the TPI's were like that, i wanna say my fan on the vette doesnt kick on till 225. cruising it stays right at 190-200, at a stop for a while itll fluctuate right at 220-230...but itll never go over 230.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
