ported MAF questions..
Old Aug 2, 2005 | 09:39 AM
Young,Fablous,&Broke's Avatar
Hmm, spend the day under the hood ripping crap out of my car, to gain absolutely nothing... no thanks!
Old Aug 2, 2005 | 09:40 AM
BDIX's Avatar
Dick is Huge!
thats me its more of a mental thing..
and the fact of having something to do.
Totalled his shit!@
Old Aug 2, 2005 | 09:41 AM
gator's Avatar
Underdog
Originally Posted by 98SOM_T/A
I plan on getting non emission longtubes + ORY as well...
think jbweld will do the trick?
no.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Aug 3, 2005 | 10:27 AM
SnowmanWS6's Avatar
Gator what about some of that grey tape that fixes everything?
2000 Trans Am WS6
1988 Thunderbird Turbo Coupe
6.0 H/C with alittle juice
http://profile.myspace.com/index.cfm...endid=59760565
Old Aug 3, 2005 | 10:47 AM
HybridSS's Avatar
I have fuzzy eyebrows
If you removed the cats you likely did go rich just a bit. But as Gator said that has nothing to do with the popping...thats an LS1 thing.
I would port the MAF ends. Do not buy an 85mm MAF. I used to run ported ends. Actually...if you want some ported ends I have a set of black ones here ill sell for $40.
Anyways...you can do a half assed port job on your stock MAF housing and have it work out ok. The only thing is it may make you run leaner...as in..too lean. No way of knowing until you put it on the dyno with wideband.
You are searching for small amounts of HP with the mods you are doing. Its very likely you could actually loose more HP due to having a small affect on AF ratio by making thses changes. The only way to see actual gains from the small stuff you are doing is to be certain your AF ratio remains optimal. In otherwords...if you hope to gain 8 hp my reoving cats....you may break even or actually lose HP because you likely made the car run richer. And you will not see that 8 HP until the AF is brough back to the correct level through tuning. Its a crap shoot to that degree with this GM car because the MAF is so sensative. If you are not monitoring your changes...this stuff may net you a big fat 0. Or...you could get lucky and see 10 hp...only one way to find out.
In the end if everything is off...youll just have to spring for tuning by a pro like Mr Formato to align things back to where they should be.
sucks modding on a budget...I know.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Aug 5, 2005 | 06:02 AM
Kurupt01's Avatar
Hey where you at in palm harbor? We should have a little mod meet, i need do my TB too.
Old Aug 6, 2005 | 09:34 AM
  #17 (permalink)
BDIX's Avatar
Dick is Huge!
or how about we just race?
your PM'd
Totalled his shit!@
