w0+0t=w00t v2.1!!!1!
Old Apr 19, 2005 | 07:42 PM
  #31 (permalink)
Tackleberry's Avatar
Animal Mother
yea i noticed that i have to give it another 1-200 rpms when sitting at an idle and then it purrs. im gonna have that done tomorrow, along with my change to synthetic oil too.
Old Apr 19, 2005 | 07:44 PM
  #32 (permalink)
formula69's Avatar
blowed up
why change to synthetic oil? all its good for is engines that get taken apart and reassembled a lot... i run regular 10w 30 or 40 and have for a long time..
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old Apr 19, 2005 | 07:49 PM
  #33 (permalink)
Animal Mother
couldnt hurt....may as well do it. 2.59 for regular high mielage oil, or 3.18 for the synthetic...it cost me 25 bucks with tax to get the oil, where before it was about 20 bucks...its worth the 5 bucks
Old Apr 20, 2005 | 06:11 AM
  #34 (permalink)
gator's Avatar
Underdog
synthetic oil will actualy drop your oil pressure due to its viscosity
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Apr 20, 2005 | 06:45 AM
  #35 (permalink)
Animal Mother
i thought it was supposed to raise it
Old Apr 20, 2005 | 07:48 AM
  #36 (permalink)
Half Fast's Avatar
LT1's are slow!
Not all synthetics are the same.
If you use Mobil 1 5-30 you will probably have a slight drop in oil pressure due to it's viscosity.
If you can find it, I'd reccomend the Mobil 1 0-40, I've switched my LT1 to this and now have slightly higher hot oil pressure.
Your problem is most likely related to your idle. You need a tune to get your idle right and to make sure that your mixture is correct and you aren't washing down the cylinder walls with unburnt fuel.
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Old Apr 20, 2005 | 08:17 AM
  #37 (permalink)
gator's Avatar
Underdog
what half fast said......
and i saiid that a few posts ago
Old Apr 20, 2005 | 02:08 PM
  #38 (permalink)
EliteZ's Avatar
Precision Motorsports
Cool. I was looking through it found all the lift/dur info I wanted.
448WHP/420WTQ
Full bolt-ons+H/C
Car Sound Clip & More(W/ Mekanic)
Tuned by Precision Motorsports
Old Apr 21, 2005 | 06:25 PM
  #39 (permalink)
plan Z's Avatar
cam'daro
Originally Posted by formula69
how long til your planning on taking the heads off?
probably not for a little while...unless i can find a set of used lt1 heads, then i will get it done a lot faster, but i havent found any for like $100 yet
