TT346 LS1 goes 8.5 @ 162 with stock crank,stock block, stock head castings
Old Sep 27, 2004 | 06:49 PM
HybridSS's Avatar
I have fuzzy eyebrows
BTW...those times were at a measly 22-23 PSI. Apparently he was running out of gear and didnt want to push it. So he is doing a gear swap this week and probably will turn the boost up more. He may hit lower 8s at 170...alot more than I expected!!
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Sep 28, 2004 | 03:31 AM
DaTruth's Avatar
Camera Car!
This is insane, but remember this is a race car. I think when turbos for our cars become more reliable in street setups I might switch to a turbo.
Single Toyota Supra Auto, Twin Turbo C5 FRC, and Chevy Duramax!!
My email:
vince99frc@gmail.com
Old Sep 28, 2004 | 04:20 PM
gator's Avatar
Underdog
yea man, nitrous is so expensive scott. maybe that is why you didnt run an expensive nitrous kit, when you can run an inexpensive turbo kit..... shrug. i have talked to ronnie and kurt urban personally and the builder says he has well over 100,000 dollars in that cheap turbo car, not counting the cost of the car. maybe he should have gone to see Sam
as for ronnie duke leaving a ton in the car...well i dont know about that. sure it was a full interior car, but far from leaving everything. that cars raceweight was 3600 lbs - but remember it is a convertable with a full cage, wheelie bars, outragous intercooler system (that mimics the ford boys). also he ran those numbers with two power adders, so i dont know about not pushing it as hard as he could. 20-22 psi through a C5r motor = a LOT of cfm. i doubt he could have pushed it 30 psi through those heads and sheetmetal intake. if he could, he would and wouldnt have sprayed it. god that cat had more money than god in his car and quarter of a million dollar tow rig/semi.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Sep 28, 2004 | 06:24 PM
gator's Avatar
Underdog
ok, sure. i dont speak spanish. aint real bright over here on this side.
your childish remarks are just lame. ignored as they insuficient. all i know is you are bashing expensive heads, cam, and nitrous. ok. good tech talk. bye.
Old Sep 28, 2004 | 06:37 PM
  #17 (permalink)
HybridSS's Avatar
Ronnie Duke does have some serious cash in that car. He still owes the people that put it together a TON of cash. He just plopped down a wad and said make it run 8s.
Harlans on the other hand was done mostly by himself...with help from a select few others.
And most of you know my philosophy on turbos. They are great for a max effort where you want to maximize a setup for a given cubic inches. In any V8 of decent size I would say atleast 700+ rwhp. Up until that point however...I like nitrous for the cost and simplicity of setup. And not many people will ever be exceeding that 700+ rwhp mark.
So to me...having a V8 turbo that makes 400-450-500 is kind of a waste.
If and when I go Turbo...I wouldnt even think about it unless I planned to be in excess of 900 hp. Even then...I will be near that number on nitrous with a measly 385 ci..
I could care less about the cool factor. I want to go consistanly fast. And up to 700 or so rwhp...nitrous is tough to beat. More than that...and you must consider a turbo.
Old Sep 28, 2004 | 07:13 PM
  #18 (permalink)
gator's Avatar
Underdog
Originally posted by Scott
I was trying to show (like Al is) that turboed cars can go fast without high dollar heads unlike compareable n/a, s/c, and nos cars seem to need.
pick your poison:
96 mph or 116 mph. go to the ford section undr "fuck" to see what i am talking about. since you like to talk about your combo so much.
logging off - Insta-gator - i like that a lot scott!
