Spark Plugs
A buddy of mine has a 98 Z(ls1) and was wondering what plugs wires to run on the car. Mods consist of NONE being the fact that its completely stock. What would be the best wires to run on this car to spark ti up a little bit?? Any info would be great
^^Makes me warm and fuzzzzy
MSD wires ohm out the best of any LS1 wire offered. They are also the cheapest....so MSD is a good choice.
However...he will see NO gains from a plug wire change unless one of the stock wires is damaged.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Originally posted by Tonedef
Doesn't matter how big the wires are unless the ignition system is upgraded..the factory coils push the same spark if you have 8mm or 10mm wires
98 Z28 A4/LS1
Sport Gold Metalic
God I Hate Ricers
98 Z28 A4/LS1
Sport Gold Metalic
God I Hate Ricers
Hes got plans for doing something with it. His previous car was a mildly modified LT1. I think he mentioned something about the LS6 mani being first.
you dont really need 10mm wires... go with MSD 8.5mm.. and with the LS1, changing the ignition means changing all 8 coil packs which is like 200 bucks a pop for aftermarket ones...not worth the cash....just make sure the spark plugs are gapped right and make sure they are long enough..
T.R. $100,000 kill club member #002
Turtle crew member #2
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
