torque converters
Originally posted by rAy_02Z28
anyway to find out if i have the optional 3.23's ????
Put the rear of the car on jackstands, get under the car, put a chalk mark on the driveshaft, have a friend spin the wheel one full rotation and count how many times the driveshaft spins.
If it spins 3 1/4 times you have 3.23s, 2 3/4 times you have 2.73s .
-Vince
-Vince
Originally posted by Jakethesnake
here is a way easier way...look on the side door, look for the code GU5 or you can do the jackstands, your choice
-Vince
-Vince
a 2.73 geared ls1 will still move well. dont be fooled into think that big gears will help out that much when you enter the world of big convertors. a good friend of mine races his 2.73 geared 3700 lbs TA (he is a fatty) with the same convertor and runs mid 11s on a mild head and cam package. the last thing i would personally worry about is rearend gears.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
i dont know why i didnt think of that
