car heats up fast...
Old May 16, 2004 | 04:16 PM
24-7's Avatar
Civic Racing eXperiment
Default Re: car heats up fast...
Originally posted by formula69
ok so my 94 LT1 heats up really fast.. like 3 or 4 runs down the 1320 and its at 210 degrees... and at 210 degrees my car runs LIKE SHIT... i lose a lot of top end power... how can i make this better? i have a hypertech and i have the thermostat set at 160 and that helped a little bit.. i dont have an aftermarket thermostat tho lol any suggestions that are low budget would be GREATLY APPRECIATED!! thanks
Put the fan on a switch. Get another fan or take the thermostat out during the summer.
Old May 16, 2004 | 07:42 PM
ZDriver96's Avatar
I dont understand ?? You have a hypertech and set the thermostat for 160 but u dont have an aftermarket thermostat?
Did u mean you dont have an aftermaket thermostat and u set the Fans to activate at 160 degrees?.
You should actually set the fans to kick on at 170 at the earliest. Unless it is really really cold it'll always run at 170 degrees or warmer. You should get an aftermarket thermostat for 160 because if its at 180 the fans setting at 160 or 170 arent really helping a whole lot plus thermostats are like what 10 bucks?
Get cold air induction if u dont already have it, do a throttle body bypass on the coolant too if u havent yet.
When your slowing down after the 1/4 pop the hood.. temp will drop pretty fast with all the air rushing in there.. just make sure your latch works properly so your hood doesnt fly off.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old May 17, 2004 | 04:06 AM
CamaroJoe's Avatar
Landscape Engineer
As far as I know, thermostats are made basically of a piece of wax and cannot be reset to another temp. The Thermostat controls the lower temp of your coolant and the fan controls the upper temp. If you rig your fan so that its running at all times, you wont heat up much higher than your thermostat's openning temperature. Also, your air conditioning and your heater are run off of seperate systems. You can pull the entire A/C system out and run the heat just fine.
-Joe
Old May 17, 2004 | 08:29 AM
racingtheburg's Avatar
Pro 5oh
He does pop his hood.The thing is it only gets hot while sitting.That means the fans should maybe stay on a little longer some how? Btw it will be at around 180-200 driving 210+++ sitting. Thats because the water inside is not moving and not cooling properly.
Old May 17, 2004 | 02:41 PM
ponchoV8's Avatar
99ProblemsButABitchAin't1
Then he should stick with the fan switch because you can turn them on while the car is off and it can at least cool the coolant in the radiator. Like I said earlier, $30.00 from SpeedSpecialty would get him a good fan switch, but like ZDriver said, TB bypass and a 160* thermostat is mandatory for LT1s as well. BTW Hypertech sucks.
What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentation of the women!" -Conan
Old May 17, 2004 | 04:38 PM
formula69's Avatar
blowed up
hypertech dropped my ETs 3-4 tenths of a second.. i gotta find directions on the throttlebody bypass.. anyone have them?
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old May 17, 2004 | 05:02 PM
  #17 (permalink)
Pro 5oh
Hyper tech was cool until it kept deleting it self lol
  #18 (permalink)
ZDriver96's Avatar
check out camaroz28.com and do a search ... theres lots around.. basically just look at the TB, unplug both rubber hoses from the Lower part of the TB and re-connect them using a plastic pipe. Yeah hypertech isnt good for a whole lot.. money better spent in real tuning equipment.
"SLOW LT1"
Blue 2005 Acura TSX
Old May 17, 2004 | 05:34 PM
  #19 (permalink)
formula69's Avatar
blowed up
i got the hypertech mainly to get rid of the governor, i paid 150 for it so im not complaining too much.. thanks on the instructions for the TBBP!
im FAT!!!!
Old May 17, 2004 | 05:40 PM
  #20 (permalink)
Pro 5oh
So scott more mods comming lol?
