Question for Al
Old Dec 28, 2003 | 04:06 PM
ZDriver96's Avatar
yeah im curious too
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Dec 28, 2003 | 06:27 PM
HybridSS's Avatar
I have fuzzy eyebrows
Yes...some of it was from aircraft. The rest was on the new lightweight carpet.
There was alot of useless stuff in that car. Once you pull the carpet out you see tons of things that can be removed or trimmed.
Some of the things i removed this time around:
*Tar like sound deadener under the dash, in the rear well. Had to use a heat gun and scraper. Atleast 15 lbs worth
*rear seatbelt brackets, various brackets 10 lbs
*passnger airbag 12lbs
*AC equipment under dash, blower etc 40 lbs
*extra wiring not used like CD changer harness 10 lbs
*hood latches and latch mechanism 12 lbs
and various other crap i cant even remeber. that added up to around 140 lbs. I added about 40 lbs with the cage. So Im at -100 there.
Next things to go in are:
* lightweight K member/solid mounts -40
*Hal adjustable shocks/springs -5-7 lbs
*Hawker lightweight battery -30 lbs
*some brackets on the nose of the car 15 lbs
and some other stuff I cant think of.
Then for track prep I will remove the two front seats and use a lightweight race seat -75lbs
I also now use a carbon fiber nitrogen bottle instead of a steel one. -25 lbs
Those are all rough estimates. The first 120 lbs we reomved was actually measured. But after that I was convinced I was getting somewhere and just continued not weighing stuff. There is lots im forgetting. The thing is...if your going to do a weight reduction program...do it all the way..or not at all. Every little thing adds up.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Dec 28, 2003 | 06:47 PM
HybridSS's Avatar
I dont know...I got it free. If I come across anymore Ill save you some. But I got that stuff from a project that was repairing a crashed King Air. It was left over.
