iTS CONFIRMED: new vette is 6.0 liter alum block
thats awesome news for us LS1 guys. I know what my next motor will be. 4 inch bore and 4 inch stroke. Someone run that to see how many cubes that is. Should be like 396 ci or so.
Anyways heres a link to some new vette info
new vette
new vette
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Pie times radius squared = area
radius = half of diameter
diameter = 4, radius = 2
3.14 x 2^2 = 12.56
area x length = volume
12.56 x 4 = 50.24 per cylinder
50.24 x 8 = 401.92 cubic inches
61.023 cubic inches = 1 liter
401.92 / 61.023 = 6.586 Liters or 6.6 Liters
3.14 x 2^2 = 12.56
Vehicle Repair/Maintenance and TIG welding services for hire (steel and Aluminium), PM or IM me
AIM: Acidtalons
AIM: Acidtalons
Sweet man...damn good with the engine math.
402 cubic inches sound mighty good to me.
Right now I have an iron 383. Going to a 402 ci aluminum that is 90 lbs lighter and 20 more ci.....sweeeet!
900 rwhp and 3150 lb raceweight!
I just hope my current motor holds up until we start seeing these 6.0 alum blocks.
Heres an easier way courtesey of Speedomotive INCs web page.
BORE X BORE X STROKE X .7854 X # CYLINDERS =
CUBIC INCH DISPLACEMENT
98 Z28 A4/LS1
Sport Gold Metalic
God I Hate Ricers
98 Z28 A4/LS1
Sport Gold Metalic
God I Hate Ricers
That works too but the .7854 in this case gives you 402.1248 Cubic inches. So its all fairly relative.
Technically there is no way to tell cause Pi is an unknown value, you can calculate it too 200 decimal places and it still keeps repeating.
Technically you could use 3.1415926535897932384626433832795 for pi which yield 402.1238 ci
However you should only use the same number of decimal places that you have accuracy in your machine tooling. For example the bore is 4.00 cubic inches but could be 4.0004 or 4.00065 or some other variable beyond your machining tolerances. So really you would have to know to what tolerance GM bores are measured.
AIM: Acidtalons
AIM: Acidtalons
Can't wait to see them on the road
