Pump gas, how fast can you go?
Old Sep 2, 2003 | 09:50 PM
Fast240Z's Avatar
The King
Default Pump gas, how fast can you go?
Does anyone have any idea about how fast you can go running just 93 octane? I have a regular old SBC with a plate NOS kit. How fast have people been able to go and still run pump gas? Any thoughts?
Mark
STS Power Dealer
www.pcstreetcars.com
Old Sep 2, 2003 | 10:30 PM
HybridSS's Avatar
I have fuzzy eyebrows
I can go roughly 600 rwhp on 93 octane. ETs and traps are still TBD.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Sep 3, 2003 | 09:07 PM
Sam@Coastal's Avatar
Does not race from a roll
my 91 Gt went 10.20 on pump gas. Prolly coulda went alot faster but this was pre wideband tuning days for me, so I always played it safe.
www.coastaldyno.com
Smackin down LS1s since 99', LQ4s too...
Old Sep 4, 2003 | 07:36 PM
Fast240Z's Avatar
The King
If I remember correctly, just a few months ago CHP mag did an artical on a BBC which made over 1000 HP on 93 octane. I don't know how streetable it would be, but I wonder. The way I see it is as long as you can control detination the sky is the limit. We run race fuel so we don't have preignition, right? If I make 600 on the motor and I spray 300 to it, as long as I am not melting spark plugs, what's the problem?
Mark
STS Power Dealer
Old Sep 4, 2003 | 07:44 PM
SPLATT's Avatar
TONIGHT....YOU....
nothin at all
"My CaR Are SlOW"
1985 monte carlo SS *under construction*
2002 T/A Firehawk #0490. M6. A few RWHP/ more RWTQ.
Old Sep 9, 2003 | 02:48 PM
Razor's Avatar
Octane requirement is greater the smaller the displacement.
Also pump gas is to be defined as 93..not 116 you got from a pump.
Only way I see to get big power on pump gas is big cubic inches with mild compression. Nitrous..no way without melting stuff.
HTH
I run pump gas..93 with alky
NEW Machine
89 Mustang GT
9.040 at 153.13 1.502 60ft Hoosiers 275/60 Jan 2012
True-Street trim
348, 88 t4 .96, pump gas
www.alkycontrol.com
Old Sep 15, 2003 | 09:51 AM
JFormato's Avatar
The Later model Gm cyl heads ie the LS1 and LS6 are far superior to those in the hot street SBC. The combustion chambers are far evolved from the SBC's and when modified are yet farther ahead. I have been able to do numerous 12:1 vehicles on 93oct and no knock, when there was spk knock I could just retard under peak torque and all is well. I have yet to see an all out setup that really pushes it as far a compression and power in a genIII SBC.
Al or hybridSS is probably the closest to this as of now making 707RWHP and 721RWTQ on a bit of spray. I know of a few TT setups making over this power level on 91oct.
Jeremy Formato
LS1/LT1/L98 Tuner Custom packages and PCM recalibrations for your Vette, Camaro, or GM truck
www.Fasterproms.com
456HP 412TQ stk heads custom cam much more to come ....
Fasterproms 813.253.0961
Old Sep 17, 2003 | 08:36 AM
97blkz's Avatar
thanks for the education bit boys!
