Pump gas, how fast can you go?
Old Oct 4, 2003 | 11:18 AM
Fast240Z's Avatar
The King
Originally posted by Razor
Only way I see to get big power on pump gas is big cubic inches with mild compression. Nitrous..no way without melting stuff.
HTH
I run pump gas..93 with alky
Sure, big cubes and a light car is a great combo. Yet I have run a sizable amount of NOS through my motor using only (93)pump gas. I have, up until recently, never had a plug problem. I also run much hotter and leaner than is recommended by NOS/NX and have had good results. Now that I am starting to really put the gas to it, I have started to have any issues(melted plugs and mid-track backfires).
I refuse to run my motor on race fuel, because I still want to drive it around without taking out a second morgage on my house. I have been considering using race fuel on the fuel side of the nitrous system from a small tank. It might be the comprimise I need to stay safe, go fast and run pump gas.
Mark
P.S. What's up with the alky?
STS Power Dealer
www.pcstreetcars.com
Old Oct 4, 2003 | 10:16 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Hmm, that's a good idea, running a small tank of race fuel for a wet nitrous kit. What all would you need for that? You'd basically need another fuel system just for that, wouldn't you?
Old Oct 5, 2003 | 07:23 AM
Fast240Z's Avatar
The King
Default Re: Re: Pump gas, how fast can you go?
Originally posted by Force Fed 23
Yeah, that your motor isn't a "regular old SBC". Your car's fast, but lets not pretend its anywhere near stock shall we?
OK, back up. What I ment was that my SBC is the older style motor and not one of the newer LS1 or LT1 motors. Sure my motor is not stock. I can't think of anything in my motor which was made by Chevrolet, even the block is aftermarket. I am not pretenting anything other than I am not poor.
Mark
STS Power Dealer
Old Oct 8, 2003 | 07:53 AM
Fast240Z's Avatar
The King
Force Fed 23,
Back in my younger days I had a small truck with a 2.3 in it and a 5 speed. It sure was a lot of fun to drive and work on. At the time I had all of the current mods done to it. I loved to see my friends faces when I would rev it to 8k. They thought I was crazy and I didn't care what happen to it. The only problems I ever had was with the altenator going bad because of the high rpms.
Mark
STS Power Dealer
Old Oct 8, 2003 | 06:44 PM
  #18 (permalink)
Fast240Z's Avatar
The King
Never really heard of alternators having issues, but most turbo guys don't spin past 7k or so (and even that takes some work since the factory EFI rev limiter is set at 6200 RPM) but my buddy in Lakeland used to spin his turbo motor to 9k with stock block/crank. Those motors are damned near indestructable kinda like aftermarket Chevy stuff
Back then I was using cheap rebuild alternators from the parts store. My 2.3 was not fuel injected, I ran a 500cfm Holley 2 barrel and an MSD 6T. The bottom end was an all stock turbo motor and the head and intake was of a carburated motor. If I remember correctly I cut 0.120" off the head to up the compression and used a sloted gear for the cam to redegree it. That was my first expriance with cam timing. I recieved some help from a friend who raced mini stocks at sunshine back in the day.
Mark
STS Power Dealer
Old Oct 8, 2003 | 06:51 PM
  #19 (permalink)
Fast240Z's Avatar
The King
Originally posted by FordMan
Have you tried running less timming ?
How about a Jacobs Mastermind controller ?
http://store.summitracing.com/productdetail.asp?p=2251
i always wanted to try one of these when i ran the juice.
Scott,
I have all the good MSD stuff and I automaticly retard my timing when the nitrous is activated. As far as Jacobs stuff, well, I have a bitter taste in my mouth from them when I had my Jeep. I am hoping when I change over to fuel injection here in the near future that some of those problems will go away. There will be a learning curve again, but you don't go fast over night.
Mark
STS Power Dealer
